Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2376 Domande Visualizza tutte
Domanda Chiusa
Gear wheel look-a-like piece left over after iPhone 4 repair.
I was following the fix it to change the power lock button, and when I removed the power lock button, then these two parts fell out. I figured out where the large piece go, but I simply can't find any images that shows a gear wheel look-a-like that I am missing.
I put the phone together and I tried to start it up, however after it showed the black screen with the apple, it never went further. So I am guessing that I need that piece.
(I then took the phone apart, and I was a bit rough with the larger piece and it's loop broke. However that is not the cause of the problems, as the problems were there before I broke it.)
iPhone 4 Power & Lock Button Replacement
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Is the screw hole missing here?
Punteggio 1
1 Commento:
You are right it was the right one. Thanks a lot!
da
That like gear thing looks like a screw hole take a pic of the mother board and I can confirm this.. And you really should have taken the screen out when repairing this as bending the lcd cable forward like that is only asking for trouble
Punteggio 0
1 Commento:
Thanks for considering my questions. I can't see any missing on the mother board. But do take a look, I have uploaded a couple pictures of the logic board.
da
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 59
