Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
U2 IC Replacement Solder?
Hello, I have an iPhone which someone has removed the U2 IC from. I have purchased a replacement U2 IC, but I'm not sure if I can do the job with a soldering iron. I'm not the most experienced solderer, so I might not even attempt it but I have some questions.
Would a heat gun be best for this?
Can I use the solder that's already there?
I will post a picture of the logic board, because it looks abnormal.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
oh my, that's a tall order.
You'll want to perfect the art of "kitchen table bga" repair on old devices for a long time before trying to place this chip that shares a border with the CPU.
This is not a DIY project.
Punteggio 2
I agree, I would suggest finding a BGA laboratory and get them to do it. Capable BGA rework stations cost thousands, however it should be fairly simple job for them to do.
Punteggio 1
Aggiungi la tua risposta
Ryan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 739
