Salta al contenuto principale
First generation of the Kawasaki Ninja 500.
How to clean the carbs
Hi I'm new to motorcycles. I just got a 1993 Kawasaki ex 500. The guy I got the bike from said he knows the carbs need to be cleaned. Can someone please tell me how to do this. ? This is my first bike so I have no clue what to do. And a repair shop wants 400 and up. And I don't have that. To spend right now. Any help would be great thanks.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Chris Hilliard, take a look on here. different bike, same idea. You can find step-by-step instructions on here. I'd suggest you get a carb overhaul kit and get to it. take your time, it is not as easy as it seems. The numbers for your Kawasaki carbs are 15002-1492 LH 15002-1493 RH. Armed with that you should find a rebuild kit relatively easy. Hope this helps, good luck.
Punteggio 1
1 Commento:
Hey, thank you so much. I wrote this down. And I'll check the site. Thanks so much. I can't wait to have her up and running.
da
https://ninja250.org/ = THE Bible for the 250cc-300cc Kawasaki’s. Good advice for all motorcycles also.
Punteggio 0
Aggiungi la tua risposta
Chris Hilliard sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 64
Tutti i Tempi: 2,436
