Salta al contenuto principale
Repair guides and support for the Acer line of netbooks including the Aspire One series.
Is it possible to replace the SSD with higher capacity?
I have an Acer Chromebook CB5-311 16GB version and I was wondering if it's possible to replace the original SSD with a higher capacity one - also which type would fit?
Questa è una buona domanda?
Punteggio 1
2 Commenti
i want to do the same thing, would love to know if anyone has done it yet?
da
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Yes It is possible to replace your SSD with a higher capacity one. To my understanding, replacing your SSD with a higher capacity one is possible as long as the voltage ratings are suitable. Try some brands like Samsung or crucial !
Punteggio 1
All SSDs are the same physical size. The process is: you have to clone what is on your small capacity drive onto your new higher capacity drive. The higher capacity drive will accept the results of the cloning. Since the cloned drive will be an exact copy of your smaller capacity drive you will now have empty space left over. Your system can't use this until you link the empty space with the allocated part of the drive.
Punteggio 0
Aggiungi la tua risposta
Iacovos Florides sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,055
