Salta al contenuto principale
The first tablet from Acer's Iconia Tab B1 family, Acer Iconia Tab B1-A71 was announced in January 2013.
Why is my picture in negative
My acer tablet has not been dropped or damaged to my knowledge. When I turn it on, the colour is all in negative. I've tried resetting and even just a simple turn off and on. Does anyone know if this can be sorted or does it need to be repaired by a professional.
Any help will be grateful
Thankyou
Questa è una buona domanda?
Punteggio 3
3 Commenti:
same goes to me. i didnt dropped it and when i turned it on after charging all the pictures turn negative.
da
have you tried to go to settings - Accessibility - Negative Colors
da
Yes I have tried setting_accessibility. But could not fine negative colors....
da
Aggiungi un commento
2 Risposte
You will need to turn of color inversion. Go to settings, click accessibility, scroll to the bottom, then click color inversion. That should fix it!
Punteggio 0
Most likely you have cracked resistor at lcd flex cable
You need to replace it with working one
https://imgur.com/a/3W99K
Punteggio 0
Aggiungi la tua risposta
Gemma sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,348
