Salta al contenuto principale
Modello A 1297 / Processore Intel Core 2 Duo da 2,66, 2,8, 2,93 o 3,06 GHz
Battery Temperature Sensor Error
I replaced my MacBook Pro Battery and after running ASD i got the following error:
[09/08/14 12:56:12] Temp (TB3T) - Battery temperature (test #1) - Sensor Reads Within Operating Range
- Check to ensure that sensor reads within operating range.
[12:56:12] ERROR -- 1 [Unable to read sensor] -- (-1.00) TEST FAILED
Can anybody help ?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Only you know if you damaged any connectors or components on your logic board during the DIY repair.
Go over all your connectors/connections again... many times DIY find that what they "thought" or "believed" was a proper connection was not square or "snapped in".... sometimes ribbon cables were not unlocked or relocked... or the ribbon not fully inserted in the connector.
If this answer is acceptable please remember to return and mark it.
Punteggio 1
Aggiungi la tua risposta
Christos M sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 796
