Salta al contenuto principale
The Huawei Ascend P7 is a 5" smartphone released by Huawei in June of 2014. Model numbers: P7-L10, P7-L00.
20 Domande Visualizza tutte
Black screen Huawei p7
My huawei p7 has a black screen and it doesnt respond anymore when i hold the power button it vibrates 1 time and when i put it in the charger my red light works on the phone and i dont know what to do because my warrant is not valid anymore somoene can help?
Questa è una buona domanda?
Punteggio 22
20 Commenti
Similar problem. The phone does not power on, I just have the front led flashing a red light, then an orange one , and eventually a green light.
da
I have the same problem.. please help!
da
Me too have same problem... I am worrying a lot. Just used for a month and now no more use :(. Even in warranty, I am in USA and no service center too :(
da
Buddy, the screen itself not turning on but inside I feel it is functioning, if some one calls it is ringing but I could not seen anything in display. It is totally black
da
Mostra altri 15 commenti
Aggiungi un commento
10 Risposte
Risposta Più Utile
I had the same problem and just opened the sim and sd cards and put them back in again. It came back on again. What a relief!
Punteggio 6
7 Commenti:
Thank you so much. Problem solved.
da
i tried but same problm
da
worked as soon as i took out the cards
da
I will try this, I hope it will work
da
i have tried all the methods nothing worked even toke the battery out nothing work still the phone is working but black screen
da
Mostra altri 2 commenti
my phone have a this problam
helllllllp
Punteggio 0
1 Commento:
I had the same problem.my phone doesnt switch on and its only blinking in red
Please help.thanks
da
Remove the back cover to check if the screen connector gets loosen and try to re-connect
Punteggio 0
2 Commenti:
and how do you do that?
da
yeah his right, how can you remove the back cover ?
da
guyz my screens only shows up during calls and when i unlock my phone. After unlocking my phone the home screen gets black and can see the bottom 3 options and can use the top slide as well but can't assess the app's that are on home screen ??? plzz help me out
Punteggio 0
lol i just changed my home screen style from top slide setting and issue resolved : D now.
no more black home screen............... wew
Punteggio 0
1 Commento:
really, that great
da
You need to flash your Huawei P7 Device using P7 Firmware, download P7 Firmware from google, and flash with that. Can you access to "Recovery Mode" ?
Punteggio 0
I can her mine but I can't see nothing
Punteggio 0
my Huawei p7 lite is black screen can’t open but I charge the it have the led light and sound others things is nothing just the screen always black screen.how to fix it
Punteggio 0
1 Commento:
I have exactly the same issue ;(
da
Please my Huawei Phone is on the power button isn’t working, the phone is on, as I keep hearing notifications but can’t open it, HELP!!!
Punteggio 0
ASSALAMUALAIKUM in my p7 phone there is a problem the problem is my phone is not charged and not open some days ago my phone is on but there is a line colour green but my phone is not on plz help me
Punteggio 0
Aggiungi la tua risposta
MsMoha1997 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 32,024
