Salta al contenuto principale
Lanciato a giugno 2012. Modello A1278. Processore Intel con Turbo Boost. Fino a 512 MB di RAM Video DDR5
1624 Domande Visualizza tutte
Domanda Chiusa
Turning itself off
My friend spilled water on my macbook.we turned it off fir 3 days.tried to turn it on but it wouldn't.he took it for repair and said its the keyboard and changed it .it worked for a month,while browsing turning off option kept poping on screen and suddenly it turned off.now when i turn on after booting to apple logo it turns off.what can it be?(even on booting on a external drive copy,after booting the turning off options pops and turns off)
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
You most likely had more than simple keyboard damage.
Follow the tags at right for an idea of what else could be wrong (corrosion) and what sort of DIY repair you'd be in for. ( FWIW Logic board replacement is a very advanced DIY project - you basically completely dismantle and then reassemble your entire machine).
In order to accomplish anything DIY wise you have to have a better identification of your machine. There are a lot of versions of the MB P going back beyond 2008 and in 3 different sizes!
After identifying the likely cause in order to fix it you will have to Study (not just read) the specific Guide, and notes for your exact machine, obtain the proper tools (every job is easier with the right tools), keep all the screws separate and identified so at reassembly you know which screw goes back into what hole.
If this answer is acceptable please remember to return and mark it.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 157
