Salta al contenuto principale
Repair guides and support for all types of building materials.
20 Domande Visualizza tutte
need to remove hold down nail without damage to metal roof
How can I remove the hold down nails {to be replace with insulated screws[from the corrugated metal roof
without damaging the metal roof? is there a nail puller
that pulles straight up and not pried up.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You may need to fashion a block of wood that conforms to the metal roof to spread the pressure of the hammer claw/crow bar base as you pry the nail.
I took two blocks of wood and two pieces of 1/4 steel placed across as short a distance as I could between the blocks. Then resting the hammer on the metal bar pulling the nails.
In my case I had raised over-lapping seams. If you have corrugated roofing that will be harder depending on where they nail it down.
Punteggio 2
Aggiungi la tua risposta
R Klein sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 7,829
