Salta al contenuto principale
The BlackBerry Z10 is a touchscreen-based smartphone developed by BlackBerry, previously known as RIM.
73 Domande Visualizza tutte
Can a Z10 be repaired once wet?
Phone fell into water. Depth less than 6" and not for more than a second. It initially powered back up but once turned off would not come back.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Rick Fink, the first thing you want to do is to stop using it. Remove the battery and use this guide to get to the motherboard. Then clean all your parts with 90%+ isopropyl alcohol and a soft brush. Check for obvious damage like burned, charred looking components. Once you are sure it is cleaned, replace the battery and see what you get. Water damage is the hardest to fix since you do not know ahead of time which parts have failed. It does not matter much on how long or how deep the exposure was. It matters what may have gotten shorted out. Hope this helps, good luck.
Punteggio 2
I have the same problem, after a day on rice it turned on for a while to show the link to www.bberror.com/bb10-0020
I bought a new battery, but now it don't even show the led light.
Any one know how to fix this? Thank You!
Punteggio 0
Aggiungi la tua risposta
Rick Fink sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,571
