Salta al contenuto principale
Modelli A1419 / Fine 2012 / Processori 2.9 & 3.2 GHz Core i5 o 3.4 GHz Core i7, ID iMac13,2
Can I replace my 1TB HDD to 256 SSD (2.5")?
I've heard someone said 27" iMac late 2012 motherboard is not support to install SSD. Is it true?
I've read ifixit.com to replace a SSD, but it is not 2.5" SSD. Can I swap out my 1TB and replace a SSD instead?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
All standard SSD's are 2.5" form factor. The one in the guide is a special Apple drive that you would have a very hard time getting.
You can still do this, by replacing the existing 3.5" drive with the 2.5" SSD. All you need it an adapter kit. I'm not sure if iFixit sells them, but I know OWC does.
http://eshop.macsales.com/item/NewerTech...
There are other ones out there, but be careful, not all of them are designed to work with the iMac's mounting system.
Punteggio 0
Aggiungi la tua risposta
Chris sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 215
