Charging problem due to problem in charging pin of Mobile
I want to change the charging pin as it has damaged ,
Questa è una buona domanda?
Sunil, it sounds like you are looking for part number 3722-002919, which is the micro USB port for your phone. You can get it from places like this as well as many others. It is soldered to the logic board, so it will require some great skills and good tools. you will have to disassemble your phone and remove the logic board to get to the port. Hope this helps, good luck.
Hey sunil,
You can buy all of the accessories you need for this certain phone here
-Hope this helped
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 803
