Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2193 Domande Visualizza tutte
iPhone 4S stuck on iTunes logo
I have an Iphone 4S stuck on iTunes logo. When I connect it to the computer, iTunes detects it as an iPhone in recovery mode but when I try to restore it, iTunes returns a 2003 error message.
I have read that this error is related to USB cable or/and USB port problems but I have tried with 3 different cables and with all the USB ports in the computer and the 2003 error is always there.
Do you know any solution to this?
Do you think it could be a battery problem?
Questa è una buona domanda?
Punteggio 5
1 Commento
I have the same did u figure what it was thanks
da
Aggiungi un commento
4 Risposte
Risposta Più Utile
Hey Sergio,
If you are using a mac disconnect third-party devices, hubs, spare cables, displays, reset the SMC, and then try to restore.
If you are using a Windows unplug all USB devices and spare cables other than your keyboard, mouse, and the device, restart the computer, and try to restore.
If this issue continues then it may be a conflicting security problem. Click here for more information on fixing general restoration issues. This link may help.
-Hope this helped
Punteggio 3
1 Commento:
Thank you for your answer!!
I don't know if there was a problem with the USBs, now I am using another computer, a macbook, and I get error 1.
Hardware error?
da
In my case, I think it is related to a hardware problem. I will open the phone to check it but it seems to be difficult to solve. It could be the logic board :-(
Punteggio 2
hello, my iphone 4s got stuck on itunes logo, my pc cant detect it anymore, the drivers cant be installed,
Punteggio 0
Try to restore your iPhone with 3uTools.
Punteggio 0
Aggiungi la tua risposta
Sergio sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 6,800
