Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2193 Domande Visualizza tutte
Blackened screen on my 4s
My 4s screen darkened to half, froze & was followed by a while after with a completely black screen. All seems to be working behind screen as far as I can judge. Phone rings OK.
I have tried shutting it down without success. I took it off charge only an hour prior to this problem. I have since put it back on charge, hoping beyond hope this may magically solve the problem. I don't think so and me thinks it is time for an upgrade!
Thank you in advance for any help. Tony.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
3 Risposte
Risposta Più Utile
Do a hard reset press power and home button togeather for 7 seconds then let go of home and keep pressing power ..
Was it dropped or anything?
Punteggio 1
2 Commenti:
Thank you Con, I thought you had breathed life into the 4s but, after 2 x 1 second flashes of the 'Apple' logo there was nothing.
No it was not dropped. It froze with a half lit screen then to black without dropping it.
Thank you again, Tony.
da
An update Con,
When trying out your suggestion, I had the 4s disconnected from power lead. Around 10 minutes later I put it back on charge and VOILA, it came to life as for turning on from shutdown.
She lives and thanks all go to you Con. Thank you again. Tony.
da
I have just had the same problem with my iphone 4s. Tried the suggested actions above posted by con and it worked. Iphone now working again. Thank you so much.
Punteggio 0
Happy to hear it worked for you aswell
Punteggio 0
Aggiungi la tua risposta
Tony sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 90
