Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
iPhone Logicboard Replacement Part Missing Need Help?
Hi as the title says i'm replacing a iPhone 5 Logicboard, but with the replacement board there's a small part missing. it's like paper thin please see attached pic for reference
As you can see the arrows pointing to the bit missing. So my question is how do i attach this ? As the part is paper thin and its connectors are tiny ? Thanks
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
TH3ORY, looks like you are pointing to the "cellular Interconnection Flex, cable that broke. You can get it from places like this as well as from here and many other places. It is soldered to the logic board, so you will have to solder it to repair. Hope this helps, good luck.
Punteggio 2
1 Commento:
Awesome Thanks, can you please advise what is the best solder kit ? As this part is paper thin.. Thanks
da
Aggiungi la tua risposta
TH3ORY sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 151
