Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Headphone Jack Static after Lightning Port replacement
I have successfully replaced the lighting connector assembly in my iPhone 5 and everything is working but there is terrible static in my headphone port. It sounds distorted and the controls on the headphone won't play or pause music. Is there a connection that I missed, or is this part defective. What can I check or tighten?
Questa è una buona domanda?
Punteggio -1
1 Commento
Ok So I decided to test a theory, I reinstalled the original Apple part theta had the lighting connector that doesn't work. The headphone jack works just fine. Still no ability to charge but that was the reason for the replacement. So It has to be another faulty part from iFixit. Calling customer support.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
did you transfer the tiny flex around the headphone jack? it is related to preventing interference in the jack
Punteggio 2
Aggiungi la tua risposta
bderenski sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 645
