Salta al contenuto principale
The third generation of the Apple iPad, released on March 16, 2012. Full 4G and Wi-Fi model repair guides. Repairs require heat and careful prying. Model numbers: A1416, A1430, and A1403.
310 Domande Visualizza tutte
Digitizer causing multi and phantom touches.
About a year and a half ago I cracked my digitizer, I replaced it myself and it has worked fine since then. Recently though I have been getting multi touches (press Z and get zzzzzzzz) and phantom touches randomly dragging and touching my screen.
I took it apart and cleaned both sides with a cleaning cloth. The ribbon looks fine, and contacts look fine but the problem still persists. I'm unable to figure out what other problems it could be.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The digitizer can just go faulty if with a small drop and I assume you replacement screen was a copy screen so it's likely to go faulty and not as resilient as an original screen
Punteggio 0
Aggiungi la tua risposta
Philip Bremer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 9
Tutti i Tempi: 106
