Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2396 Domande Visualizza tutte
LCD displays properly intermittently, otherwise backlit grey: Why?
Replaced front glass/lcd/touch screen a few days ago. Since then, after the screen autolocks, about 50% of the time after I hit the home button, the screen comes on as it should. The other 50% of the time, it lights up but is solid grey (backlight comes on, so not black, but no image). If I turn off autolock – once the display is on, it stays on as it should (it does not randomly go grey). When grey, the touchscreen still works and a screenshot will not be grey - the screenshot is of the image that the lcd SHOULD be displaying. Could degreaser help? I did not clean the contacts with windex when I put it back together. Could the connection just be loose? Could it be a faulty lcd?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Check the screen to logic board connections and let us know what happens.
Punteggio 0
1 Commento:
I popped off and then put back on the screen to logic board connections. The problem is the still the same.
da
Aggiungi la tua risposta
Josh Freeman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 195
