Salta al contenuto principale
Modelli A1419 / Fine 2012 / Processori 2.9 & 3.2 GHz Core i5 o 3.4 GHz Core i7, ID iMac13,2
Stock Dual HD setup, SSD blade upgrade?
I have the 3.4 i7 27" imac with the Dual HD setup (at purchase).....256GB Blade SSD with the 2TB HDD. Anyone ever seen the SSD inside before? i know it's the blade, but what interface? was it PCI-E, Sata, MSata,?
Im looking to upgrade to a larger SSD, but really only want to have to take this thing apart once.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
AFAIK there is no 3rd party provider of Blade SSDs to fit these and other Blade models because they use a proprietary interface.
OWC usually is the first to identify and offer such upgrades. I see none at their site.
FWIW should a Blade SSD become available it looks to be a daunting and time consuming process to replace it.
If this answer is acceptable please remember to return and mark it.
Punteggio 2
If it's the 2011 model that you are referring to, then it doesn't have a blade SSD. The SSD installed is a 2.5" SATA III that is mounted behind the Optical drive. They didn't start using the bladed SSD's on iMac's until the 2012 model.
Punteggio 0
Aggiungi la tua risposta
cyankain7 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 256
