Salta al contenuto principale
Repair manuals and support documentation for devices used in a health care setting or procedure.
324 Domande Visualizza tutte
X-Ray machine has Dos/4gw fatal error (1307): not enough memory?
hi to all,
we have an x-ray scanner but recently we had an error which won't let the x-ray os to start
the error is as follows:
You can see on the attachment for more details
your help will be appreciated!
Sincerely,
Shpend h.
Update
Guys thank you for your help,
This is what i did, since im not advanced in DOS. You can see the attachment of the memory type,
Please if you can send me the dos commands how to proceed how to solve this problem.
Sincerely,
Shpend H.
Questa è una buona domanda?
Punteggio 2
1 Commento
use the type autoexec.bat command and tell us what your autoexec.bat shows
da
Aggiungi un commento
5 Risposte
Risposta Più Utile
Someone else maybe able to offer more info on your X-Ray device.
Here's something that might be useful: DOS/4G and DOS/4GW FAQ
From what I can glean from the FAQ DOS/4GW is an extender which allows Real Mode DOS applications access to the extended memory space (Protected Mode).
Did you add any new apps or updated any? There may be something loading that is using all the extended memory so DOS/4GW can't load. You could be loading it twice as well as the first instance is stopping the loading of the second copy (which is where the error maybe coming from).
Punteggio 3
Shpend, first you should tell us which X-ray machine you have. As a general information, remember that DOS/4GW is a 32-bit DOS extender. It will all DOS application to access memory above the 1MB limit. Your problem may be with the conventional DOS memory, which is the memory up to 640K. If you can check your autoexec.bat file and it might help if you could post your lines from autoexec.bat as a comment. I would add mem /c /p before the loading of DOS4GW. that way you can at least see how much conventional memory you have. If any of the memory under 640K is not recognized, you can get the error you are inquiring about.
Punteggio 1
1 Commento:
As usual, @oldturkey03 is likely on the right path. I’d be interested to see what is in the autoexec.bat file. With mid-90’s software and 16MB of RAM, something got corrupted. I’d also take a look at that hard drive. It might be time for some maintenance on the file system.
da
Yes, you need to specify which X-ray machine you have. Generally, DOS/4GW is a 32-bit DOS extender has 1MB limit. X-ray medical device comes in different variety; hence it’s essential to tell the product info. However, as OTS said, if your problem is with the conventional DOS memory, you can check their autoexec.bat file that might be of help. Even you can take help of technician that could be able to resolve this problem.
Punteggio 0
I guarantee you regardless of the device the answer is: RE-install software.
Punteggio 0
BestSource Nutrition provides supplements to boost immune system. We provide best supplements for body health.
https://www.bestsourcenutrition.com/
Punteggio 0
Aggiungi la tua risposta
Shpend sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 26
Tutti i Tempi: 2,052
