Salta al contenuto principale
The 7 inch third generation of Nook color tablets by Barnes & Noble, not to be confused with the 9 inch Nook HD+.
30 Domande Visualizza tutte
Need a source for replacement battery.
I have searched for a replacement battery for the Nook HD to no avail. All that can be found are not for the HD. None have the 4000MHA, 14.8 Wh rating.
Does any one know of a source, other than B&N (who won't sell the battery) ?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
jmbiii3, the battery number for your Nook HD is BNA-B0002. the battery appears to be available right here and here as well. Of course, always check with the vendor. If you are truly fixed on the 4000mAh you can check on here
Punteggio 1
1 Commento:
Thanks ! The battery in the HD is a 4000mAh and I would like to keep it at that rating. I'd order the one you mentioned last, but can't quite read the order info. LOL
da
Here you go!
https://www.newpower99.com/SearchResults...
Punteggio 0
Aggiungi la tua risposta
jmbiii3 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,354
