Any luck on replacing a Dock Connector?
Attempted twice and afterwards the device fails to initialize that the charger has been connected.
Anyone had any luck with replacement?
Questa è una buona domanda?
The dock conector that was replaced is original or at least a good quality?
Can also be a component that is responsible for identifying the cable does not work in this case would be very hard to fix it ... unless there the same component on the iPhone 5/5S and then to replace it buy soldering
The dock connectors were purchased from etrade supply, so I would consider them pretty good quality. The solder tech I had replace the dock connectors is one of the best soldering techs I have seen with over 20 year experience. I inspected his work under microscope and the soldering job is flawless.
I have received the cable error message a few times when connecting the lightning cable to the device. I have ruled out cable brands as I have tried OEM, MFi certified, and other ones; still comes up with an error message.
Which component do you think I should consider looking into to replace?
Thanks,
www.mycelcare.com in dubai.. i am their client too. trustworthy centre
Fault does not recognize the cable reminds me of the problem of the iPhone 5 u2
U2 responsible for identifying the cable and serves as a kind of starter while charging, try to search the component is similar but the problem that this device dont have scheme
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,436
1 Commento
Has anyone been able to successfully replace an iPad Air dock connector?
Thanks
da Nick
