Salta al contenuto principale
Guide di riparazione e smontaggi per PC portatili di tutte le forme, dimensioni e colori.
18859 Domande Visualizza tutte
How do I do a system recovery on an MSI S6000 laptop?
I installed a new Hard drive on my MSI S6000 , but now I dont know how to do a system recovery.
I screwed up ( I think ). I installed Windows 7 Ultimate ( OEM Version ) on the laptop thinking I would be golden ( using the CD Key from the laptop ) , but its not.
I would like to restore the laptop to factory settings , but I dont know how , or if I even can.
Questa è una buona domanda?
Punteggio -1
1 Commento
You can not do that without the old HDD. What happened when you installed Windows? What is going on with your computer right now?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I hope you still have your old HD and its working. If you do put it back into your system. Then get a USB to SATA adapter cable and clone your current drive over to your new drive. Once you have the drive cloned you should then be able to swap the drives.
Punteggio 1
Aggiungi la tua risposta
joe sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 250
