Salta al contenuto principale
A touchscreen smartphone made by LG released in September 2013 with the model number VS980.
20 Domande Visualizza tutte
How much would it be to fix my cracked screen
screen is cracked cant touch anything on my screen
Questa è una buona domanda?
Punteggio 7
Aggiungi un commento
3 Risposte
Risposta Più Utile
ahmena, that depends on where you buy the parts. I suggest you purchase the complete digitizer/lcd and frame assembly. It is very difficult to separate the LCD/Digitizer and replacing the complete assembly will make it easier. Get the disassembly guide from the bottom of this page. The speaker, camera, and the rest of the parts on the frame are glued on the frame. Hope this helps, good luck
Punteggio 3
I just purchased the entire LCD Assembly at www.gounlock.com for $64.99--you can also try www.wholesalegadgetparts.com and www.Mengtor. All are pretty reasonable. Good Luck!
Punteggio 0
Mine cracked from left and has a line and when i want to pull my notification down it wont let acces near that area what do i do
Punteggio 0
Aggiungi la tua risposta
ahmena sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,222
