Salta al contenuto principale
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 Domande Visualizza tutte
Samsung galaxy s4 touch problem
Hi, I've repaired tones of Samsung Galaxy S4 and around 3 months ago the S4 touch goes crazy when I remove the glass and when I put the new glass on it works fine. I repair using LOCA by the way. never had this issue till 3 months ago and only happens with S4
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hello Hamied,
I have seen this problem before when using the LOCA and my advice would be to start using OCA instead as it has never caused this problem for me. Also it is a lot less messy. It does require an auto clave instead of UV Light. Hope this helps!
Punteggio 1
1 Commento:
Thank you for the reply. Do you or anyone know where I can get an autoclave at a reasonable price??
da
Wirelezz Toys is a good dealer.
Punteggio 0
Aggiungi la tua risposta
Hamied sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 862
