Salta al contenuto principale
Acer entered the world of laptop computers in 1997 when it purchased Texas Instruments' mobile PC division.
1682 Domande Visualizza tutte
Domanda Chiusa
How can I fix my laptop?
My laptop doesn't seem to be working when I turn it on it loads a screen saying
Recovery
The application or operating system couldn't be loaded because a required file is missing or contains errors.
File \Windows\system32\winload.efi
Error code: 0xc000000f
You'll need to use the recovery tools on your installation media. If you don't have any installation media(like a disk or USB device), contact your administrator or PC manufacturer.
(I don't have a disk or USB device)
Questa è una buona domanda?
Punteggio 0
1 Commento:
It is always a good idea to let us know what computer you have and what operating system you are using.
da
Aggiungi un commento
2 Risposte
Ryan , this error indicates that your boot code on your system partition is OK and BIOS ly runs it, but after that it cannot access the volume that is pointed by boot code where the EFI file is located. Take a close look at this forum. Check the answer from the_spacekadet and see if it will work for you. Hope this helps, good luck.
Punteggio 0
Download that file from the internet then restart your system. and if this will not work go with online technical support.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 474
