Salta al contenuto principale
L' Apple iPhone 5c è stato annunciato il 10 settembre 2013. La riparazione di questo dispositivo è simile ai modelli precedenti e richiede cacciaviti e strumenti vari. Disponibile nelle versioni: GSM o CDMA. In tagli di memoria da 8, 16, 32 GB. E nei colori: bianco, rosa, giallo, blu e verde.
1233 Domande Visualizza tutte
Why won't it turn on after battery replacement?
The 5C came to me with a shattered screen. I fixed the screen and it would not turn on. I tested the screen and it works on another 5C. I replaced the battery. The battery works on another 5C. I have tried holding the home button and the power button to reset it. That will not work. I have plugged into the computer. Will not charge. The working 5C worked on the computer. I tried plugging it into the wall. The wall charger worked on the working 5C. What else could possibly be wrong with this phone?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
6 Risposte
Have you tried DFU mode and then itunes?
Try to hold the power and homebutton for a really long time (like a minute or so)
Punteggio 0
Had this same problem and The phone is still just sitting
Punteggio 0
If it was working before a screen replacement and now you have no power, I would be looking for a missing/damaged component on the board near the battery connector.
Punteggio 0
I had a similar issue, our IPhone 5C will not turn on. I tested the battery and the screen on a second IPhone 5C and both worked. All connector are secure. I'm searching for an answer to this problem.
Punteggio 0
Did anyone find an answer to the above question?
Punteggio 0
I had the same issue, try DFU mode and restore with iTunes, after that the iPhone will turn on. But if you have the battery at 0% and turns off the issue can happen again.
Punteggio 0
Aggiungi la tua risposta
keldavis5 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,969
