Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2399 Domande Visualizza tutte
Domanda Chiusa
Phone dies prematurely (20%, 59%, 80%, 3%) unless plugged into charger
My iPhone 4 has been dying all the time. At various percentages - 20%, 60%, 4%, 80% - it doesn't seem to matter.
It happens when I am on various apps - email, text, camera, maps - and when I am on a phone call.
It tends to turn back on straight away when I press the power button, but can take quite a long time to load up.
It does not die if it is plugged into the wall charger, my laptop to charge, or the car charger. I am now only making calls when it is plugged in.
Is it simply that the battery is old and needs to be replaced (I bought the phone in 2010)? Or could it be a software bug?
Thank you, Maddie
Apologies if a repeat - I tried to find this Qn but couldn't.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I would change the battery all your symptoms point to a bad battery
Punteggio 0
1 Commento:
Thank you Con.
da
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,218
