Salta al contenuto principale
Processore dual core Intel Core i5 da 2,3 o 2,6 GHz o quad core Intel Core i7 da 2,7 GHz (fino a 3,7 GHz con Turbo Boost) con 6 MB di cache L3.
Anyone tried removing/replacing individual keys?
I have a client with a "sticky" spacebar. I am hesitant to remove the key for cleaning for fear of either breaking the key/assembly, or not being able to get the key back on properly. I've done this countless times on previous models, but give the uniqueness of this machine I thought it may be beneficial to ask first. Thanks!
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
2 Risposte
Soluzione Prescelta
No different than the others.
Apple so far has removable key caps (including the space bar) across all of their laptops so people can swap out the caps for a different language set.
Here's a good Youtube on how: How to remove and clean Macbook Pro keyboard keys
Hope this helps
Punteggio 4
Tried to remove the backspace, enter and shift keys and resulted in the clips breaking and have to order new keys.
Hope this helps
Punteggio 2
3 Commenti:
Where did you order your individual keys?
da
Give these folks a try: TheBookYard
da
Thank you Dan for sharing this info and geni499 for asking.
da
Aggiungi la tua risposta
Grillwrecka sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 30,908
