Salta al contenuto principale
iPod charging but not fully...
When I plug it in, it shows a red sliver of battery and a lightning bolt. After a while, it boots into the OS. The problem is that it warns you there's less than 10% battery left and the battery icon no longer shows a lightning bolt. I can't get the battery to keep charging. Does this mean the battery's at the end of its life?
Questa è una buona domanda?
Punteggio -1
2 Commenti
Ok, I just got a better theory. I peered into the dock port down there and found that the little circuit piece is wobbly and one of the pins (it looks like #1 or #2) has been pushed into the back wall and bent up.
da
I've also found out that pin #1 and #2 are grounding pins. So maybe this explains why it charges at first but stops once it boots up? I guess the OS checks for the pins and manually stops the charging if one of them is missing? Now.. if I could find a software fix for a hardware problem, that would truly be amazing.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I would bet dead battery. you should be able to change it, if using one of the guides... it is an old device, battery is nearing its end anyways...
Punteggio 0
Aggiungi la tua risposta
AndrewNoNumbers sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,661
