Salta al contenuto principale
Guide e supporto per varie marche e tipologie di televisioni (TV).
9091 Domande Visualizza tutte
Sony Bravia KDF50E-2010 50" LCD HD TV won't power on?
Hello,
I have a Sony Bravia KDF50E-2010 50" LCD HD TV. The red light flashes three times.
What shall I do or what part should I purchase to fix on me own Sony Bravia 50" tv?
When I try to turn it on first green light flashes about 25-30 time. Then I get one red light and the other red is flashing 3 time (continuesly).
Is it worth and possible to fix?
I will be really grateful for your help!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Martin Hawrylo,
If your television is not turning on or showing any signs of life, see the Insignia NS-24ER310NA17 Will Not Turn On problem page for possible causes and solutions.
This error can be caused by a bad bulb, or a bulb that is not tightly secured as well as the the lamp door isn't tight. Check on those things first. Hope this helps, good luck.
Punteggio 1
Aggiungi la tua risposta
Martin Hawrylo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 460
