Salta al contenuto principale
1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
192 Domande Visualizza tutte
Upgrade I/O board USB 2.0 to USB 3.0
Hi friends,
My name is Fábio and I would like upgrade the I/O board USB 2.0 to USB 3.0. Is it possible?
My computers is a "MacBook Air 11" Mid 2011".
The actual board 2.0 is working well.
Regrads,
Fábio - Brazil.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Soluzione Prescelta
"Belkin Thunderbolt Express Dock" as an external solution should work. But it is a $200 solution so i think a new laptop is a better idea.
Punteggio 1
Risposta Più Utile
Sadly the I/O board does not hold the USB controller chip. That function is part of the Intel platform controller hub chip which is on the main logic board. The chip you see on it is the audio codec.
Punteggio 1
3 Commenti:
Thank you. I understood. Is there something that can be done to upgrade the system to USB 3.0?
da
Sadly no. All laptops use a unitized controller chip these days that services all of the CPU's I/O needs. This chip is part of the main system board and is not replaceable (soldered). If USB 3 is that important I would recommend you look at buying a newer system and selling your current system.
da
Actually it is possible with external solution. I found this product. "Belkin Thunderbolt Express Dock".
da
Thanks everybody,
I think that exchange the currently system is the best option.
Best regards,
Fábio.
Punteggio 0
Aggiungi la tua risposta
fabiohfs sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,858
