The Bluetooth® Mouse Cursor Has Erratic Movement
or Is Not Moving
Reinsert the batteries or install fresh batteries, for more information on how to install the batteries refer to theKeyboard Manuals.
(Make sure the red light on the bottom of the mouse is on).
Make sure the opening on the bottom of the mouse is clean.
Make sure the mouse is within 10 feet (3 meters) of the computer.
Make sure the surface you are using has enough of a pattern in it so that the mouse can see it, a mouse pad is best, (the mouse judges movement by reflections, a uniform surface is harder for the mouse to tell when it has moved).
Restart the computer.
Install the latest Bluetooth drivers, for more information refer to,
Fix, Connect to and Learn About Bluetooth®
Re-pair the mouse to the computer for more information refer to,
For additional information on Bluetooth mice and keyboards refer to,
http://www.dell.com/support/troubleshoot...
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
6 Commenti
Are you using Windows 7 or XP?
da mayer
I'm using Windows 7
da hami
What computer are you using it with?
da mayer
Toshiba satellite L755D-21J
da hami
Are you talking about the trackpad or are you using an external mouse?
da mayer
Mostra 1 altro commento
