What do I do if I have an error 07 message?
My xbox has the red and green blinking light, the disk drive won't open, and it reads "07" in the top left corner of my TV screen when I turn my xbox on.
Questa è una buona domanda?
Hi,
07 - kernel - HDD timeout
Most of the times, the IDE cable is not properly connected when you see this error. Please reattach the ide cable. Not only to the harddisk drive but also to the dvd drive. ALso try to reconnect the ide cable to the motherboard.
Press pretty hard so it goes all the way in. Make sure it is seated straight and proper in the drives and the motherboard. If you still have an error 7. Try another ide cable. If that won't work try another harddisk. If there is still no go, try to set the jumpers on the rearside of the harddisk drive. Set it to master or cable select.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 72
Tutti i Tempi: 7,223
