Salta al contenuto principale
The Xoom Wifi is the second of two versions produced by Motorola. The device was released on March 27, 2011. Repair of this device is simple, requiring screwdrivers and plastic opening tools.
How similar would the repair guides be for the other Xoom versions?
I am concerned that I have a different version. I appreciate the organization in the repair guides for this one. It would be convenient if I could simply use these guides.
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
2 Risposte
Soluzione prescelta
The only difference between the Motorola Xoom Wifi and the Motorola Xoom 3G/4G is that the 3G/4G version has the ability to connect to the cellular data network. Where the connector and antennae would be in the 3G/4G version, there is just blank space in the Wifi version. If you are careful, you should be able to repair your Xoom with these guides.
Punteggio 4
1 Commento:
Thank you Mallika. And such a quick response.
da
Jelly Bean 3.4 4.1 or 2 whenever you can I get it to upgrade to a newer version And I have another tablet to an older one because the Verizon model and It can't Can't do nothing on it I tried to reset it and make it work again and it Coming back saying that one wire is broken or something then it's not taking a charge but when you plug the charger into it it charges up. Do I need to send to somebody or can I take it apart myself and fix it Thank you
Punteggio 0
1 Commento:
Dad asking a question I didn't know it said something about an answer I don't know s*** about whatever the question was so I'm looking to have somebody answer my question. Answer to question anything
da
Aggiungi la tua risposta
Dylan Dickstein sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 27
Tutti i Tempi: 655
