Salta al contenuto principale
Model A1137 / 1, 2, or 4 GB capacity / black or white plastic front
68 Domande Visualizza tutte
Why is my computer not recognizing iPod 1st Gen Nano?
I recently bought a used iPod nano 1st gen. I hooked it up via usb cable to my computer, it charges fine but it is not recognized by my computers USB removable hardware. I have 4th GEN nano that works fine the same USB cable. I tried resetting the 1st GEN nano and it doesn't solve the problem. What could it be?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi,
maybe its formatted to MAC and you have a PC. Set the iPod into Disk Mode and then restore it via iTunes.
How to set the iPod into Disk Mode can be found here:
http://www.command-tab.com/2006/03/30/hi...
The combinations of the 5th Gen iPod should work for the nano too. If not, let us know and we will search for the right combination.
Punteggio 0
same issue, except I can’t use disk mode at all. can still use radio remote and listen to the 96 songs i’m now stuck with
Punteggio 0
Aggiungi la tua risposta
Mindy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 9,139
