Salta al contenuto principale
The Gateway MA6 is a business class laptop that features an intel pentium M processor and a 15" LCD display. It was originally released in early 2006, with the model number M465-E.
3 Domande Visualizza tutte
Why does my computer shut off every time I unplug it?
Every time that i unplug my computer, it immediately turns off and will only power back on after being plugged in.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Your battery most likely needs to be replaced. This can be easily tested if you know someone else with a similar model computer, by swapping out batteries and testing. The battery on the Gateway MA6 is easily accessible, and there are guides available here. that outline the procedure.
Punteggio 2
Mine does this as well. Usually it's because the battery wasn't all the way in, I just take it out and lock it back in correctly, and it seems to fix it.
Punteggio 0
Aggiungi la tua risposta
Patrick Michniuk sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,269
