Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
iPhone 5 water damage
Hello
I have an iphone 5 which is water damaged
I've soaked it into a bath of isopropyl alcohol during a night
After drying
i've tried to test it but nothings happened
only the motherboard is heating up..
Could you help me ?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
heat = a short on the board.
You need to desolder the EMI shields in order to expose most of the board. Find the components that are oxidized--reflow the solder on those components and replace those that are damaged.
clean flux, wash again, dry, assemble with new battery into a test housing and see what you get.
If this isn't feasible, then send it out for a professional water damage repair---be sure to ask if the company plans to follow the steps outlined above, otherwise it will be the same as you've already done.
jessa
Punteggio 1
1 Commento:
You're right
I haven't desold the EMI shields
i think too that i have oxidized components under the shields
tomorrow I'll try to do that
hope that it will work !
thank's
da
Aggiungi la tua risposta
Balou17 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 448
