Question mark when MacBook turn on?
When I turned on my MacBook, a question mark pop up without the apple logo or the spinning wheel?
Questa è una buona domanda?
Either your HD is trashed, or corrupt. You can boot from your install CD/DVD and run Tools->Disk Utility->Disk First Aid Tab->Repair Disk. (Do not do an install).
If you don't have/can't find your install disk you could try booting into single user mode and running a utility from the command line.
' Startup in single user mode ( hold down command-s after the boot boing ) you'll see white text on a black screen. When it stops loading/scrolling type /sbin/fsck'' press return.
If the above fails boot in target disk (hold down the T key until you see the firewire symbol {looks like a stylized Y}
Good Luck.
N.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,737
