Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Domanda Chiusa
What are the problems for an iPhone 5 to not power on?
Hello,
my Iphone 5 does not power on when I hold the power button. So i thought that the flex cable from the power button is the problem. I replaced it and the phone still does not power on.
If i connect the phone with iTunes it gets on and it shows the iTunes logo.
Also I can not restore the phone, probably because of a jailbreak? I do not know this because I bought it from someone.
In addition the home button does not work , too.
What do you think is the problem?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
does it fire up any errors when its trying to restore
Punteggio 0
8 Commenti:
no errors it just say that itunes could not restore this phone.
da
i think there is a problem with the U3 chip.
da
De luna before you jump to blaming the motherboard I would try a new battery it can cause a phone not to restore! Also put the phone in dfu mode and try the restore
da
I tried today again to restore the phone with iTunes and I get error 21.
Both power and home button do not work thats why I think that there is a problem with the U3 chip.
da
I no a error 21 is a battery error
But if power and home have stoped working then yes it's a board problem but a new battery will make the phone restore and will be usable
da
Mostra altri 3 commenti
Yes I belive it's possible I don't do board repairs myself but there is a woman on here that does called Jessabethany she has extensive knowledge on board repairs want will be happy to help
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 150
