Salta al contenuto principale
Manuali di riparazione per oltre due decenni di portatili Mac: iBook, PowerBook, MacBook, MacBook Pro e MacBook Air.
30536 Domande Visualizza tutte
Domanda Chiusa
External Drive Unexpectedly Ejects while transferring files
I've got a mid 2012, 13-inch MBP. I replaced the optical drive with a 1Tb HGST Travelstar. I used an MCE Technologies Optibay kit. I wanted to carry an on board mirror of the boot drive.
The computer treats the new drive as a mounted, external drive. There are numerous reports of external drives being unexpectedly ejected during large file transfers. Does not happen for small moves, say under 4GB at a time.
This essentially eliminates the possibility of using the drive as a backup. Purportedly, this started to occur after the 10.8.5 Mountain Lion Supplemental update.
Any thoughts on a remedy?
Thanks,
J
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
You might try doing this while plugged into mains power, and - changing energy saver settings to NEVER sleep the computer, and, NEVER put the HD to sleep.
Failing that - come up with a new backup strategy (e.g use a pocket drive (or convert your optibay drive to a pocket drive) via USB).
If this answer is acceptable please remember to return and mark it.
Punteggio 1
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 825
