Salta al contenuto principale
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
Does the Ipad 2/3 use the same LCD?
Hello my Ifixit friends!
Does the Ipad 2/3 Use the same LCD?
Thanks a lot for your help! :)
/EDIT: I noted Ipad 4 does NOT use the same LCD as neither IP2/3..
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Hi
No way, the resolution is different, and the connectors are different.
iPad 2 LCD
iPad 3/4 LCD
Regards.
Immagine Replace a screen compatible with the A1395, A1396, and A1397 model 2nd Generation iPad tablet. Part #L097X02. 9.7". 1024-by-768 resolution, 132 pixels per inch (ppi).
Prodotto
iPad 2 LCD
$59.99
Immagine Replace a 9.7-inch LED-backlit display screen compatible with a 3rd or 4th generation iPad tablet models A1416, A1430, A1403, A1458, A1459, and A1460. Part #6091L-1579A, 821-1240-A.
Prodotto
iPad 3/4 LCD
$59.99
Punteggio 2
That's funny--the iPad 2/3 no. But yes, you can use a 3 LCD in a 4.
Punteggio 1
what about a vintage Ipad can I use a 2 or any more recent LCd, I doubt it?
Punteggio 0
Aggiungi la tua risposta
Alexander sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,561
