Salta al contenuto principale
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Domande Visualizza tutte
Domanda Chiusa
Can I get data from my unrepairable iPod 4th gen?
I have an iPod Touch 4th gen 32 GB which was working fine then stopped charging. I ordered a battery from iFixit and carefully did the repair - pulling in an expert friend for the soldering - but no luck - still dead. I suspect it could be the charging port or a mistake on the soldering. Can I get any data (photos) from this device by removing a card/chip and using a card reader or is this data not able to be recovered?
Questa è una buona domanda?
Punteggio 1
1 Commento
This question was migrated from http://meta.ifixit.com/Answers.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
The iPod Touch 4G uses Toshiba NAND flash drive memory for data storage, and accessing this (by taking it out and putting it into a working iPod Touch, for example) is almost impossibly difficult.
For more info you can check out the teardown, or perhaps this answer: Toshiba NAND Flash Memory - one or two chips?
Punteggio 1
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 803
