How to eliminate clanking noise from water heater tank?
Is there a way I can clean the water heater tank to eliminate the noise? How? Any equipment needed?
Questa è una buona domanda?
Water heaters need to be drained (actually on a yearly basis). You'll note a water faucet valve on the lower part of the tank. Hook up a heavy duty garden hose to it.
Step 1: Turn off the Water Supply
If you have an electric water heater, turn off the power at the breaker-box. If yours is a gas heater, turn the thermostat to the "pilot" setting. Connect a hose to the drain valve located close to the thermostat, but don't open the valve yet. Turn off the cold-water supply that feeds the water-heater.
connect hose to drain valve
Step 2: Drain the Hot Water
Inside your house, open up one of the hot-water faucets in one of your sinks or tubs. This will prevent a vacuum from forming in the lines. Go back to the water-heater, and open the drain valve to drain the hot water out of the tank. Make sure the far end of the hose is draining somewhere that won't be harmed by hot water. An outside driveway is ideal.
draining the hot water heater
Step 3: Flush out the Remaining Sediment
Once the water stops flowing out of the far end of the hose, turn the water supply back on. This will flush out any remaining sediment left behind in the heater. Once the water runs clear from the end of the hose, close the DRAIN valve. Don't forget to turn the hot-water faucet inside your house back off.
The heating element could possibly blow if there is no water in the tank. Some tanks may need to be completely full in order to prevent damage. When in doubt, always read the warnings and instructions on the tank label carefully because each tank may vary!
Step 4: Test the Pressure-Release Valve
Turn the power-supply to the water heater back on at the breaker box (or the thermostat), after the tank has filled with water. Once the water temperature has been brought back up, test the pressure-relief valve according to the manufacturer's instructions. This safety device is designed to prevent excess pressure build-up or overheating inside the tank. If it's faulty, you may need to have it replaced by a licensed plumber.
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 10
Tutti i Tempi: 1,465
