Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Getting help with unreconized part
Hello,
After replacing LCD screen I've noticed a tiny part that pop-out from the phone but I don't know where it's belong.
I'm assume that it's related to the proximity sensor cause since the LCD replacement it's not working properly.
Please tell me where to put that part.
Thanks.
http://s30.postimg.org/8ex897pzl/IMG_392...
Questa è una buona domanda?
Punteggio 1
1 Commento
Does anyone knows how those it called? I've lost it and I'm trying to find it on eBay.
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
The part is not the actual proximity sensor itself, it is simply a part for aligning it.
You can go to the repair guide step by clicking here.
It can easily fall out after you remove the earpiece.
I hope this helps!
Punteggio 1
1 Commento:
Thanks!
Do you know how those it called? I've lost it and I'm trying to find it on eBay.
da
That part goes in just to the right of the front facing camera. When you put the camera shield on the top left screw should go through that little hole
Punteggio 0
Aggiungi la tua risposta
Maor sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 75
