Salta al contenuto principale
Una console di gioco per la televisione prodotta da Sony Computer Entertainment, conosciuta anche come PS4. Annunciata il 20 febbraio 2013 e lanciata sul mercato il 15 novembre 2013.
1696 Domande Visualizza tutte
NTSC 110 v For Kuwait
hello
about the PS4 NTSC i saw a picture here that it works on 100 - 240 V .
but under my device there is a note " 110 V " , does it mean ONLY 110 V or its the same like 100 - 240 V ??
by the way i am from Kuwait and sometimes we recieve 220 - 260 V , is there any problem ?
thank you
Questa è una buona domanda?
Punteggio -1
1 Commento:
مرحبا يا خال
اشتغل معك في الكويت؟؟ رجائا رد
Did it work good in Kuwait without a convertor?
da
Aggiungi un commento
1 Risposta
nawaf, "The power supply is rated at an AC Input of 100-240 volts. This means you can take your game around the world with your trusty PS4 always at your side; just remember to bring your power socket adapters. " from here."
Since you seem to have quite the power spikes "220 - 260 V" I would just use a surge protector. Otherwise you will be fine with using it in Kuwait. Hope this helps, good luck.
Punteggio 0
Aggiungi la tua risposta
nawaf sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 215
