Salta al contenuto principale
The PlayStation Vita is the successor to the PSP. It contains a beefed up processor and graphics, and includes the addition of a second analog stick. It was released February 15, 2012.
169 Domande Visualizza tutte
I have a stripped case screw... how do I remove it?
I'm trying to follow the Vita 'replace the left joystick' guide and ran into a problem - I can't remove one of the screws on Step 1. I was able to remove the other 7 case screws, and even reach in to unplug the battery and touch screen cables, but...
... I'm worried that I can't just force it apart without damaging the right button board. What do I do?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Get a dollar-store eyeglass repair kit that contains those tiny screwdrivers. Select the best fitting one, and dip the point of the screwdriver into a drop of superglue (not so much that you end up gluing the damaged screw into the housing). Glue cheap screwdriver onto damaged screw, and when the glue has set, lefty-loosey and away you go.
Punteggio 0
Aggiungi la tua risposta
rayhaven5618 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 14
Tutti i Tempi: 3,547
