I purchased my Yoga 2 13 (non-pro) from BestBuy. It came with the 500GB SSHD + 16GB SSD. That actually means that this is a 500GB HD with a built-in 16GB solid state cache. This is a hybrid drive. It is a 5mm high drive with a new style connector, not a standard 2.5 inch drive connector. There are no consumer 5mm drives available currently. You will not be able use a 2.5 inch SSD.
However, this Y 2 13 also comes with a M.2 type 2280 SSD slot. I purchased and installed a Crucial M550 128GB M.2 card (CT128M550SSD4) from Newegg. It is $99. This card is very fast in my Yoga.
Here is the CrystalDiskMark:
1000MB Read Write
Seq ----- 479.5 - 369.9
512K ---- 439.7 - 369.4
4K ------- 27.17 - 68.44
4KQD32 - 339.3 - 265.6
So for a cost of $799 for Yoga (sale) and $99 for the SSD, I have a Yoga 2 13 with 628GB of storage and a fast Windows drive. It boots to the desktop in less than 13 seconds.
The PCMark 7 score is 4935.
BTW, you can see a full dis-assembly of the Yoga 2 13 here:
http://www.myfixguide.com/manual/lenovo-...
By the way, the Yoga 2 Pro also uses a small SSD card, smaller than my SSD card.
Votato
Annulla
Punteggio
4
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
1 Commento
I would recommend you give their support line a call to see what they can tell you. I tried reviewing their web site but it was a bit confusing as they have a few different Yoga models.
da Dan
