Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2193 Domande Visualizza tutte
Weak wifi signal after upper antenna flex cable replacement
I recently replaced a screen on a iphone 4s when the screw that holds down the wifi cable was stripped. When i tried to remove the stripped screw i accedently teared the whole wifi cable. I finaly got the screw out and i ordered a new flex cable. I replaced the flex cable and the wifi worked again. The wifi works great, but when i go a little far away from my router the signal is a little weak. My brothers iphone 4s has 2 in signal but i only get 1.
Anyone have any idea what the problem could be?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
The RF-connector or the wifi filter on the PCB could be damaged.
Goto a service center for a fix, because both are soldering actions.
Punteggio 0
Aggiungi la tua risposta
Iver sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 178
