Salta al contenuto principale
Released in June 2011, this Dell notebook is a standard laptop for basic computing needs. For its relatively cheap price tag, it provides basic computing power for general computer work.
7 Domande Visualizza tutte
Why won't my charging cord charge the computer?
I can't get the charging cord to charge my computer.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
There are a few possible reasons for this, and here are some links to the troubleshooting page along with explanations:
1. Your charging port may be broken. This is most likely the case if your port looks damaged.
2. Your motherboard might have an error. Most likely, if this is the case, you won't be able to use your computer when it's plugged in, either.
3. Your battery might be broken. If your computer works fine on the charger, but the battery won't hold a charge, this is probably the case.
Hope this helps!
Punteggio 2
Aggiungi la tua risposta
Michael McNutt sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 289
